Bobs Ten
RV-10
Prepare Door Channel for Seal
1748 - 1912
Used the same technique to create a 1/4" uniform gap between the door and channel.
First covered door surface with packing tape.
Applied 3/16" x 1 1/4" weatherstripping over tape. The tape actually expanded to almost 1/4", so we will see what the result is.
Applied another layer of packing tape over the weatherstripping. The tape serves as a mold release as the epoxy won't stick to it.
Apply epoxy, flox, cabo mix to the door channel edge,
Close and clamp the door in position such that epoxy was squeezed between the door channel and taped door surface.
Remove excess epoxy.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
