Bobs Ten
RV-10
45-05.1>7
Bond Door Panels
1418 - 1706
After reading the forums, I decided to add some clecos to the top door flange for clamping purposes.
Drill cleco holes using #40 drill.
Remove doors, debur holes.
Mask fuselage for bonding using packing tape.
Clean and prep door panels for bonding.
Wet out parabeam structural filler.
Mix epoxy, several batches, slow hardener.
Apply thin layer of epoxy on door panel bonding areas.
Apply parabeam pieces to inner door panel.
Mix more epoxy, cabo per plans.
Apply epoxy-cabo to all bonding surfaces.
Join door panels using clecos per plans.
Cleco door to fuselage and cabin top.
Clamp door pillars using numerous spring clamps.
Cleco all holes.
Using finger pressure and small roller, pressed flanges together. Press crania, door latch area,l and elbow area together.
Duct tape flanges to fuselage.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
