Bobs Ten
RV-10
Trim Inner and Outer Door Panels
1318 - 1430 1548 - 1724
Verify all marker lines.
Drill index holes at dimple location in outer panels, 12x.
Trim outer panels to lines indicated in plans using metal shears, dremel and diamond wheel. Outside perimeter was cut first, then window perimeter.
Cleco outer panel to fuselage using index holes, check fit.
Drill index holes at dimple loactions in inner panels, 12x.
Trim inner panels using dremel and diamond wheel. Outside perimeter cut first, then window perimeter.
Cleco inner and outer panels together at two lower window index holes. These two index hole were the only ones to line up on either door assembly.
Match drill remaing index holes, cleco to fuselage.
Check fit.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
