Bobs Ten
RV-10
Install Wing Root Fairing Nut Plates
1818 - 1942
Final drill holes in bottom tank skin for nut plates using #19 drill, 4x.
Using an 8-32 screw and nut, position K1100 nut plates for match drilling.
Match drill nut plates and tank skin for nut plates using #40 drill, 8x, cleco as drilled.
Remove clecos.
Debur all holes.
Dimple center holes for #8 flush screw, 4x, using hand squeezer.
Dimple nut plate mount holes in tank skin using hand squeezer.
Dimple nut plate mount holes using hand squeezer.
Cleco nut plates in position.
Rivet nut plates using p-squeezer.
Machine c-sink holes in tank skin/flange for #8 root fairing dimple.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
