Brief Description: Install Flap Position Sensor Arm
1848 - 1912
I had to 3d print the sesnor arm again as I was having delamination issues with the nylon print. I spoke with the filament manufacturer and they recommended increasing the extruder temperature by 10C. Printed new arm using the new temp and am now satisfied with the arm.
Once again, checked the travel of the position sensor and verified that the linkage had no interference throughout it's full range of travel. Also, verified end points with flaps full UP and full DOWN.
Satified with the position of the arm on the torque tube, location was marked.
I attached the arm and filler piece using 3M VHB double sided tape.
Verified position by running the flaps up and down.
Final installation of the sensor arm and filler piece was accomplished using a SS Breese clamp around the arm and filler.
