Bobs Ten
RV-10
Install Flap Position Sensor
1300 - 1412
Fabricate sensor mount from .125 aluminum angle.
Match drill angle to RAC Position sensor using #30 drill, final drill using #28 drill.
Position K1000 nut plates, match drill mount holes using #40 drill.
Debur and smooth angle, machine c-sink nut plate mounting holes.
Drill mount for CS4-4 flush rivets, machine c-sink holes.
Verify fit and travel of sensor.
Trim mount angle to fit inside flap torque tube cover.
Match drill footwell inboard skin for sensor mount using #30 drill.
Debur all holes.
Cleco mount to footwell skin.
Rivet mount to footwell skin using CS4-4 rivets.
Attach ball joint ball to sensor and torque tube arm, loctite used on all threaded parts.
Attach sensor to mount using 6-32 screws.
Attach linkage to sensor ball and torque tube arm ball.
Verify fit and travel.
Flap torque tube arm will be secured with SS hose clamp and 3M VHB tape.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
