Bobs Ten
RV-10
43-10.1>3
Fabricate Cabin Top Rivet Strips
1630 - 1754
Remove clecos and aft top rivet strip.
Locate side rivet strip and clamp in position, flush with cabin top edge.
Match drill strip using #30 drill, cleco as drilled, every other hole.
Match drill remaining holes.
Mark aft end of strip for trimming.
Repeat for other side.
Remove all clecos and strips.
Trim strips as required.
Debur all holes, smooth all edges using s/b wheel.
Verify fit of all 3 strips.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
