Bobs Ten
RV-10
12-3.7>10
Fiberglass HS Tips
1700 - 1800
Remove previously glassed tips from HS.
Trim most of excess fiberglass.
Remove temporary rib.
Clean inside of tip of debri.
Cut two additional layers of 9 oz cloth per plans.
Wet out smaller piece of cloth and apply it to the inside of the tip close out.
Wet out larger piece of cloth and apply it over the smaller piece.
Ensure cloth lays flat against all surfaces, working out any bubbles.
After epoxy has started to set, cleco tips to HS.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
