Bobs Ten
RV-10
12-2.1>3
Install Elevator Tips
1530 - 1736
Verify depth of elevator tip flange was 1/2". Both tips were very close to the nominal value.
Using permagrit file, square the flange shoulder per plans.
Remove small square of flange along TE of tip to provide clearance for the elevator TE wedge.
Smooth edges and radius corners using permagrit tools.
Insert tip in elevator and ensure tip fully forward.
Match drill tip flanges to elevator skins using #40 drill, cleco as drilled. Ensure flange shoulder tight against elevator skin.
Verify TE of fiberglass tip is even with elevator TE. File and smooth tip to match elevator using permagrit tools.
Repeat for other side.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
