Bobs Ten
RV-10
Rivet NACA Vents and Cable Fairings
1212 - 1330 1400 - 1624
Match drill previously fabricated vent doublers using #40 drill, cleco as drilled, 8x.
Remove clecos.
Debur all holes.
Install every othe cleco.
Rivet fuselage skin, vent, and doubler using 3X gun and tungsten bar, 40x.
Rivet outside rudder cable fairings to fuselage skin using 3X gun and tungsten bar, 12x.
Rivet inside rudder cable fairings using LP4-3 and LP4-4 pulled rivets and p-rivet puller.
Remove excess proseal from around all vents and fairings.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
