Bobs Ten
RV-10
Install Flap Actuator
1248 - 1330
Fasten flap actuator rod end bearing to flap crank using drilled bolt, castle nut, and cotter pin.
Torque bolt and install cotter pin.
Torque actuator mount bolt to eliminate end play.
Install cotter pin.
Install safety wire from actuator upper lip around end bearing spacer per plans.
Verify interference free movement of flap actuator, crank, torques tubes, and horns using 12V regulated power supply. Verified stop to stop movement.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
