Bobs Ten
RV-10
38-10.2>10
Install Rudder Cable Guides and Links
1330 - 1548
Locate and drill #27 hole in two cable guides.
Locate and mark center line on backside of undrilled guides.
Match drill remaining cable guides using #27 drill.
Final drill guide mounting holes in tunnel walls using #27 drill.
Debur holes.
Install cable guide using pre drilled hole in guides.
Align centerline with remaining mount hole.
Match drill cable guide using #27 drill.
Debur all holes.
Install cable guides usinf recommended hardware.
Final drill tunnel wall for cable guide clamps.
Install cable guide clamps.
Install rudder cable links.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
