Bobs Ten
RV-10
OP38-2>3
Fabricate Aileron Trim Servo Mount
1200 - 1424
Final drill all 1/8" holes using #30 drill.
Final drill servo flange holes using #28 drill.
Cleco previously fabricated and primed spacers between servo mount plates.
Rivet center spacer set using p-squeezer.
Install bellcrank per plans using clevis pins and cotter pins.
Fabricat mounting flange for DB-9 connector using shear, brake, and panel punch.
Match drill servo flange mount hole into connector mount using #28 drill.
Match drill spacer mount holes using #30 drill.
Match drill connector mount holes into servo mount using #40 drill for flush rivets.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
