Route and secure pump wiring and stall warning wiring.
Verify pump runs with power attached.
Install fuel line from pump to bulkhead fitting, EZ Lube used on threads only.
Install ER tank.
Temporarily install fuel line from ER tank to fuel pump.
Route pump wiring and stall warning wiring so as to not interfere with anything in the pump bay or the aileron pushrod. Used nylon tywrap mounts to facilitate routing. Wiring then routed through previously installed conduit to root of wing.
