Bobs Ten
RV-10
Install Left ER Tank Vent, Fuel Pump
1348 - 1642
Locate and drill bottom skin for ER tank vent.
Fabricate vent line per plans.
Install B nuts and sleeves, flare tubing using double flare tool.
Install tank and verify fit.
Position and clamp fuel pump doubler to wing rib.
Match drill pump mount hole to rib using #40 drill, cleco as drilled.
Drill doubler rivet holes in rib and doubler using #40 drill.
Final drill holes using #30 drill.
Final drill pump mount holes using 1/4" drill.
Position nut plates for pump mount bolts.
Match drill rib and doubler using #40 drill.
Remove all clecos.
Debur all holes, smooth all edges using s/b wheel.
Machine c-sink doubler for flush rivet at nut plate mounting holes.
Cleco doubler in place.
Rivet doubler using p-squeezer and 3x rivet gun.
Position and cleco nut plates.
Rivet nut plates using p-squeezer.
Clean rib bay of all chips.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
