Bobs Ten
RV-10
Install Wing Tip Rib
1630 - 1730
Install wing tip.
Install cleco in tooling hole in wing tip rib.
Position rib in wing tip using cleco in tooling hole for control.
Used a nominal 2 3/8" from TE per plans. About 2 7/16" - 2 1/2" would be a little better.
Layout rivet line using approximately 1 1/4" spacing.
Drill aft most hole using #40 drill, cleco.
Flush edge of rib to wing tip edge.
Drill forward hole, cleco, repeat for top skin.
Drill all holes using #40 drill, cleco as drilled.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
