Bobs Ten
RV-10
Fabricate Tank Stiffener
1400 - 1700
Located and drill pilot holes in ER tank flanges using #40 drill.
Install and clamp tank to wing rib.
Match drill flange holes to rib.
Remove tank.
Shear 040 sheet in to 3" lengths for stiffener brackets.
Debur and smooth all edges of stiffener brackets using s/b wheel, 16x.
Cut 3/4 angle for stiffener, debur and smooth all edges using s/b wheel.
Layout stiffener rivet line on rib, drill pilot holes .
Clamp angle to rib, match drill stiffener using holes in rib, using #40 drill, cleco each hole as drilled.
Drill out applicable rivets in wing skin.
Clamp stiffener brackets to angle.
Match drill skin holes in brackets, cleco as drilled.
Clamp brackets to angle.
Remove all clecos, remove stiffener assembly.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
