Bobs Ten
RV-10
23-2.2>4
Fabricate Aileron Torque Tubes
1618 - 1736
Verify torque tube correct length, 90 5/8", 2x. torque tubes were previously cut and primed.
Layout six holes on each end using paper tape template.
Center punch hole locations.
Drill holes using #40 drill, drill press, V blocks.
Install threaded ends into torque tubes to shoulder.
Match drill rivet holes using #40 drill, cleco every hole.
Final drill all holes using #30 drill.
Debur all holes, vacuum dust from torque tubes.
Cleco threaded inserts into place.
Install rod end bearings. Verify finished nominal length of 94 7/16", center to center.
Rivet threaded inserts to torque tubes using p-rivet puller and MSP-42 rivets, 24x.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
