Bobs Ten
RV-10
Install ER Fuel Tanks
1442 - 1700
Inventory ER tank kit.
Per ER tank installation manual:
Locate and drill pilot holes in inboard tank support brackets using #30 drill, 16x.
Label brackets 1-4 for Left wing, 5-8 for Right wing.
Clamp brackets to 4" tubing length in X pattern, using "Breeze" clamp.
Center bracket assembly in lightening hole, one rib inboard from outermost forward rib.
Centering was accomplished by adding 4 pieces of 1/2" plywood to 4" tube between each bracket. Plywood pieces were held in place using hot glue.
Match drill pilot holes in rib using #30 drill, cleco each hole as drilled.
Final drill all holes using #12 drill, cleco each hole as drilled.
Remove bracket assembly.
Debur all holes.
Cleco assembly to rib.
Install brackets using AN3 hardware, torque to 25 in/lb.
Apply torque seal.
Install ER tank in wing.
Locate and mark top aft tank corner 9/16" below top wing skin.
Clamp in place.
Manual now calls for installing wing tip to verify clearance.
Will now start section 24 and fit wing tip, using Click Bond nut plate install kit.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
