Bobs Ten
RV-10
Fabricate Andair Valve Mount
1030 - 1300
Using the Andair valve, I needed to move the stock mount and fabricate a new one.
Previously located, marked and drilled 3/4" angle for new mount.
Cleco angles to tunnel.
Fabricate valve mount plate from .063 sheet.
Locate and drill mounting holes in sheet.
Temporarily attach valve to mount plate with screws and nuts.
Clamp plate to angles in tunnel.
Measure and cut extension rod to length.
Install extension in valve.
Install tunnel top with valve handle on tunnel. Verify extension rod properly inserted in handle collar.
Verify correct location of valve. Ensure extension perpendicular with handle and valve.
Match drill mounting holes in angles and plate.
Remove angles from tunnel.
Dimple holes in tunnel sides for flush rivets.
Final drill mount plate and angles using #19 drill.
Install nut plates on angles.
Debur and smooth all edges using s/b wheel.
Fabricate doubler for tunnel top from .032 sheet.
Match drill all holes.
Locate and drill holes for double rivets.
Machine countersink tunnel top for flush rivets.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
