Bobs Ten
RV-10
QB Wings
Install Fuel Senders, Aux Tank Bungs
1312 - 1600
Visually inspect inside of fuel tank from sender unit hole.
Using a short wrench, verified that vent line fitting were tight.
Clean sending unit hole area with s/b.
Using acetone, cleaned this area until rag came back clean.
Clean sending unit base.
Clean aux tank fitting area with s/b.
Clean tank bung using s/b and acetone.
Mix single use Proseal per directions.
Apply proseal to fuel tank rib around sending unit hole.
Apply proseal tosending unit base.
Install sending unit using AN515-8R18 screws. Prior to installing screws, rolled threads in proseal.
Tighten screws evenly, create fillet between rib and sending unit. Proseal over screw heads..
Repeat for other side.
Apply proseal to aux tank bung and fuel tank rib.
Cleco bung to rib.
Rivet bung to rib using included closed end rivets, 6x.
Create fillet around bung and over rivet heads.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
