Bobs Ten
RV-10
QB Fuse Antenna
Fabricate Antenna Doubler
1154 - 1354
Design and fabricate antenna doubler for CI-122 Com Antennas. Will be mounted under aft seats.
Design 3 sided pan doubler on 032 aluminum.
Shear to size.
Smooth all edges using s/b wheel.
Bend three stiffener sides using pan brake.
Fabricate fourth side stiffener from 032 aluminum using shear and brake.
Locate and drill clearance holes for existing rivets.
Locate and drill holes common to doubler and stiffener.
Machine c-sink required holes.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
