Bobs Ten
RV-10
32-3>5.1
Tailcone Attachment
1530 - 1812
Cleco tailcone skins to mid fuselage skins.
Cleco F-1006B bulkhed to aft tabs in baggage floor ribs.
Final drill holes in tabs using #30 drill.
Align longeron apex, top and bottom, clamp in position.
Match drill aft longeron holes using #30 drill, final drill with #12 drill. Install bolts as holes are drilled.
Fabricate two shims from 032 aluminum.
Cleco forward top skin to structure.
Match drill holes in top skin to longerons.
Match drill holes in triangle portion of skin using #40 drill.
Final drill holes in angled portion of triangle portion of skin.
Final drill all common holes with F-1006 bulkhead using 340 drill.
Match drill aft line of holes in bottom mid skin using #40 drill.
Remove top skin.
Machine c-sink holes in longeron skin and underlying skin for #40 dimples.
Remove tailcone from mid fuselage.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
