Bobs Ten
RV-10
QB Wings HID Light
QB Wings HID Lights Install
1530 - 1900
Continue working on HID install.
Install mount.
Fabricate top retainer.
Clamp retainer to skin.
Match drill holes using #30 drill.
Remove retainer.
Debur holes, dimple for AN426 rivet.
Machine c-sink retainer for dimples.
Cleco retainer to skin.
Rivet retainer using p-squeezer.
Fabricate bottom retainer
Clamp to skin, match drill 3 holes.
Dimple holes for #6 screw. Noted screws provided do not fit flush in dimple, will replace with AN507 hardware.
Machine c-sink retainer for rivets and 3 #6 screws.
Cleco retainer together.
Rivet retainer and plate nuts using p-squeezer.
Install lense and mark cutout per instructions. NOTE: with mount installed there is not adequate room to install lense. Removed mount.
Trim lense width, then top to fit.
Using duct tape pull per instructions, fit lense to top retainer.
Mark bottom retainer holes when lense was tightly fit.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
