Bobs Ten
RV-10
16-1>4
Inspect and Complete QB Wing Top Skins
1424 - 1724
Verify every step of Section 16, Top Wing Skins.
Final drill inboard rib flange for plate nuts using #40 drill.
Noted that the QB wing was not riveted in the correct hole for the MS21051 platenut.
Drilled out misplaced rivet, 2x.
Final drill platenut center holes using #19 drill, top AND bottom skins.
Final drill platenut mount holes using #40 drill, top and bottom.
Machine c-sink platenut mount and screw holes in top skin except for the most aft which was dimpled.
Dimple platenut mount and screw holes in bottom skin except most aft mount hole which was machine c-sinked.
Rivet platenuts to respective holes noting placement of K1100, K1000, and MS25051 platenuts, using p-squeezer.
Verify all other steps in section 16.
SECTION 16 COMPLETE.
Remove fuel tanks in preparation for section 19, stall warning install and ER fuel tank prep.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
