Bobs Ten
RV-10
11-7.5>8
Install Rudder - Empennage Attach
1212 - 1300 1330 - 1354
Install jam nuts on rod end bearings for rudder, 3x.
Thread rod end bearings into rudder, setting center line to spar distance at 3/4", top and bottom.
Install rudder on VS using top and bottom bolts.
Verify free movement of rudder, stop to stop.
Verify proper rudder throw of 35 degrees, measured per plans, at 2 3/16". Needed to file
rudder stops slightly.
Remove rudder.
Install center rod end bearing, set to 3/4".
Install rudder and check proper alignment of center rod end bearing with AN3 bolt.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
