Bobs Ten
RV-10
Empennage Attatch, Locate and Drill Elevator Horns
0942 - 1006
Clamp both elevators in trail position.
Verify elevators are aligned.
Locate and mark most aft elevator horn.
Drill aft most horn using 3/16" drill.
Fabricate elevator horn spacer from plywood. Verify drill press plumb with table. Drill 3/16" hole in spacer using drill press.
Install spacer using 3/16" bolt, clamp horns to spacer.
Carefully match drill second elevator horn through first horn and spacer.
Final drill Holes with #12 drill.
Remove clamp.
Install AN3 bolt and nut in elevator horns and spacer.
Remove clamps holding elevators in trail position.
Verify elevators move from maximum deflection up to maximum deflection down. No binding or rubbing noted anywhere within maximum travel limits.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
