Bobs Ten
RV-10
Attatch Elevators to HS
1424 - 1536
Chuck e-drill bushing in drill press and sand until fit in elevator center bearing was obtained.
Insert e-drill bushing in elevator center bearing.
Secure elevator in trail position.
Match drill left elevator horn through e-drill bushing.
Remove left elevator from HS.
Final drill elevator horn using 1/4" drill.
Debur hole.
Install jam nuts onto rod end bearings and install rod end bearings into right elevator per plans.
Mount right elevator to HS.
Verify maximum elevator travel for right elevator.
Secure right elevator in trail position.
Insert e-drill bushing into elevator center bearing.
Match drill elevator horn with e-drill bushing.
Remove right elevator.
Final drill horn using 1/4" drill.
Debur hole.
Mount both elevators on HS.
Install AN4 bolt through center bearing and horns, using adequate washers between hinge brackets and bearing.
Secure both elevators in trail position.
Identify most aft elevator horn.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
