Bobs Ten
RV-10
Empennage Attach Left Elevator
1424 - 1618
Install jam nut on rod end bearings.
Install rod end bearings in left elevator until bolt hole center was 7/8" from spar web.
DID NOT TIGHTEN JAM NUT AT THIS TIME.
Position HS on bench. HS must overhang bench for elevator horns to clear bench in full down position.
Used a piece of 23/32" plywood as a HS rear spar shim. Sanded shim to 11/16".
Screwed HS to bench with 4 screws with washers.
Temporarily mounted left elevator to HS.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
