Bobs Ten
RV-10
Fabricate Tailcone Aux Tray
1412 - 1548
Test bend .040" 2024-T3 aluminum for tray.
Layout tray on aluminum sheet.
Shear to size.
Debur and smooth all edges with bench sander and s/b wheel.
Bend tray edges using pan brake.
Match drill tray to bellcrank bracket.
Cleco tray to bellcrank bracket.
Level tailcone laterally, level tray and clamp to previously made bracket.
Mark bracket for final size.
Match drill holes in tray and bracket.
Remove clecos.
Finish bracket to size and debur and smooth all edges.
Final drill common holes in bracket and tray using #12 drill.
Locate and match drill bracket for nut plates.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
