Bobs Ten
RV-10
10-13.6.7, -14.4.5
Cleco Tailcone Attachment Bar Support, Elevator St
1330 - 1430
Position attachment support angle on stop/doubler and aft deck.
Clamp angle to aft deck.
Match drill support angle to the aft deck using #30 drill.
Final drill end holes using #12 drill.
Position and center elevator stop on aft deck, even with cut out in aft deck. Clamp in place.
Match drill holes in elevator stop into aft deck using #30 drill.
Debur and smooth all edges of tailcone access plates.
Cleco tailcone access plates into position.
Final drill attachment holes in the tailcone acess plates using #28 drill, 8x.
Remove access plates, final drill nut plate mounting holes, 16x.
Mark RIGHT SIDE skin to be trimmed.
Debur and smooth all edges of the shoulder harness anchors using bench sander and s/b wheel.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
