Bobs Ten
RV-10
10-12.9, -13.4.5.6
Final Drill Tailcone Top Skins, Aft Deck
1054 - 1206
Final drill all common holes in tailcone top skins, bulkheads, frames using #40 drill. Did NOT drill anything in F-1006.
Locate F-1011D and F-1012D from IFLYRV10.com.
Verify that aft deck matched with apex of longerons.
Verified rivet centerline drawn on F-1010B spacer was visible throught the holes in the aft deck.
Match drill 6 holes in aft deck to spacer and longerons, using #30 drill.
Match drill all common holes in the aft deck and longerons, using #30 drill. Cleco every hole.
Final drill 2 outboard holes lined up with F-1010B, using #12 drill.
Final drill 4 1/8" holes in F-1011B using #30 drill
Final drill 2 3/32" holes in F-1011B using #40 drill.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
