Bobs Ten
RV-10
10-12.1.2.3.4.5.6
Cleco Tailcone Top Skins, Stiffeners
1436 - 1624
Separate the forward top skin from small piece using dremel tool.
Debur and smooth all edges of the top skins and trim pieces using bench sander, s/b wheels, and 400 sp on a rubber block.
Debur and smooth all edges of F-1009 frame with s/b wheel.
Cleco F-1009 to aft deck, final drill holes with #30 drill, 8x.
Flute frame flanges per plans.
Position top skin stiffeners.
Cleco aft top skin to frames, starting at the top center and working to edges. Cleco at least every other hole.
Center the aft rivet center line of each stiffener per plans.
Match drill stiffeners on rivet centerline, cleco every other hole.
Finish match drilling all stiffener holes using #40 drill.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
