Bobs Ten
RV-10
Install Elevator Trim Tab Hinge
1718 - 1842
Cut two 35" hinge sections.
Mark and drill the end of each hinge per plans.
Cleco hinge to elevator using previously drilled hole.
Align hing with the edge of elevator, drill and cleco middles of hinge. Drill and cleco end of hinge to elevator.
Match drill all common holes between the elevator and hinge, alternating from the center. Cleco every other hole as drilled.
Cleco trim tab to hinge using previously drilled hole.
Align trim tab with hinge and elevator. Checked that trailing edges were straight using a level as a straight edge.
Drill and cleco other end of trim tab.
Match drill all common holes between trim tab and hinge.
Mark end of hinge at edge of elevator.
Remove all clecos.
Cut hinge along mark, leaving pin long. Debur and smooth ends of hinge with bench sander and s/b wheel. Debur all holes.
Cleco hinge to elevator and trim tab in preparation for riveting.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
