Brief Description: Rivet Elevator Aft of Rear Spar
1718 - 1754
Cleco remaing holes in elevator skins.
Rivet skins using p-squeezer except for the trailing most rivet on the bottom skins. Used a 3/16" flat bar, ground to fit in between rib flanges, to indirectly drive the rivet against a back rivet plate. Took a little time and a lot of hits but results were good.
Riveted the close out tabs to the shear clips adjacent to the trim tabs using CS4-4 hand pulled rivets, then riveted the remaining hole with another CS4-4.
