Brief Description: Rivet Elevator Root Ribs, Horns
1212 - 1254
Cleco elevator root ribs to spar.
Rivet root ribs using p-squeezer and no-hole yoke.
Install plastic bushings per plans.
Cleco elevator horns to root rib and spar.
Rivet horns using p-squeezer, alternating side to side and top to bottom. Manufactured heads on the thinner aluminum spar, shop heads on the thicker steel.
