Brief Description: Rivet Horizontal Stab Skin to Front Spar
1542 - 1700
Rivet horizontal stab skin to front spar. Started on centerline, riveted every other hole to first inspar rib on right side, bottom. Repeated for left side bottom. Removed clecos, riveted holes to first inspar rib, right side, bottom. Repeated for left side bottom.
Repeated alternating pattern to next inspar rib, both sides, bottom.
Turned horizontal stab around in cradles.
Repeated alternating riveting on top skin, through second inspar rib.
