Bobs Ten
RV-10
Prepare Horizontal Stab Front Spar
1130 - 1300
Remove flashing and smooth all edges of HS front spar doubler.
Cleco doubler and front spar attachment brackets to front spar.
Clamp bottoms of attachment brackets to .125 x 1.5 x 1.5 steel angle to provide flat surface for brackets.
Match drill all bracket holes, one at a time, cleco each hole.
Final drill all common 1/8" holes in spar and doubler, except as noted, with #30 drill.
Match drill 4 3/16" holes in spar web and spar caps. Final drill with #12 drill.
Machine CS 8 holes in doubler, per figure #1 on 8-5.
Final drill middles 9 holes in top and bottom spar flange with #40 drill. Machine CS each of these holes.
Disassemble HS front spar, debur all holes.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
