Reassembled VS spar with clecos in every other hole.
Set up pneumatic squeezer for thickness. Definitely glad I got the adjustable ram...
Rivet VS spar, starting in the middle, alternating side to side.
All rivets complete except for the inboard hinge bracket holes, as the squeezer yoke will not fit. Will have to use offset rivet set and bucking bar this weekend with Kyle.
While learning to use the squeezer, "smileyed" 4 of the 470 style rivet heads. This was ok because I learned how to drill them out. All 4 heads were drilled, then the shanks were punched out, holes intact.
