Brief Description: Completed fuel system, began wing attach & electri
Completed 1/4" fuel return line fabrication and installation. As noted in the fora, I should have dome some of this--the thru-bulkhead connector in particular, earlier than the descructions direct. Had to find a set of crow's foot wrenches to complete installation. Assembled Fuselage/Wing pin assemlby(Section 29-02) but will not do trial fitting of wings until some help is available. Starting assembling the wing electrical connector UHMW blocks.
