Brief Description: Completed 3/8 inch fuel line installation.
Obtained a 1/.4-28 tap to get the nutplates for the fuel flow meter bracket to behave, and then installed the fuel flow meter. Modified the plywood bulkehad I attached to the firewall to make way for installation of the gascolator, and installed the gascolator. Then made the fluel cut off-to-fule flow tubing and the fuel flow-to-gascolator tubing and installed. Attempted installation of the bulkehad fuel return fittings, running into installation problems.
