Brief Description: Joined fuselage with tailcone, prepped seats
Bent tabs on top of tailcone, and then joined the tailcone to the fuselage. Clecoed together, then riveted shoulder strap lugs to upper tailcone. Riveted tailcone/fuse. Delayed attaching turtledeck skins and aft window on advice of other builders.
Prepped sheet metal and aluminum angles for seats.
Haruko riveting th bottom of the fuse/talicone connection
