Brief Description: Installed fuel tank sight glass
Prepped sight glass and backing plate, mixed a small batch of devil's snot, and did the dreaded task of installing the sight glass. It was definitely hand to have the favorite wife assisting. When installing screws, you must use a toothpick to dob some devil's snot on the bottom of the screw head. Haruko did this by holding the screw head with the end of a magnetic pickup tool, and inserting the snotted screw into the tank hole, where I then took over, holding the screw in place while putting the washer and nut on. Afferwords, I used a 20CC veteranariand syringe to help snotting up the screws and nuts on the innards of the tank
cubist rendition of the creator working the inside of the sight glass
Outside view of installed sightglass--still has some amount of devils snot on some of the holes
