Completed landling light prep: drilled holes for landing light holding brackets, cut and polished acrylic lens.
Began right wing assembly:
Rived doubler and enboard flaperon bearing to rear spar root. Unpacked main spar and riveted brackets for five outboard spars, and completed riveting of factory-installed inboard spar brackets. Riveted main and nose ribs. Attached front edge spar. Attached and riveted three main lower/leading edge wing skins. Turned the wing over and installed two flaperon hinge brackets. Clecoed three upper wing skins in place--no time to rivet--called it a long, long day.
