I decided to do most of the landing light work before closing out wings. Cut out hte template for the landing light holes and applied it to the outoboard bottom wing skin. Used an Adel nibbling tool to rough cut he main landing light hole, and a spring-loaded center punch to mark the remaining holes for the bracket and lens. Filed the hole smooth, deburred, etc. Clecoed the skin onto five of the nose ribs (which are not yet attached to the wing spar) to get the proper curvature for the leading edge, and mach-hole drilled the lens. Assembled the light-holding brackets and the backing plate/nut plates for the lens Still need to trim the lens plexiglass
