Brief Description: Built & Installed RT. Seat Panel
I prepared the cardboard template and then cut the sheet metal pattern for the right side seat panel. I used the brake to form the 90 degree flange, then finished the forming using a steel bar the same diameter as the seat brace and a vice with rubber faced jaws. It figures that I'm finally starting to get the hang of this sheet metal stuff just as I'm nearly done with the cabin construction.
