Built the Elevator with electric trim tab. Construction went as planned until fitting the elevator to the stabilizer. It was then that I discovered a small twist in the elevator. One tip was raised 10mm and I immediately determined that the twist was not acceptable. New elevator sheet metal was ordered and I wil rebuild the elevator making sure it has no twist.
