Brief Description: Assemble cylinders and pistons to case
The pistons were installed in the cylinders using a ring compression tool. Gray RTV was applied at the base of the cylinder. The pistons were assembled to the connecting rods and the retainer springs were instaled. The cylinder/piston assembly was clamped in place using plastic tubing, washers and nuts. The assembly was per the SPA manual and recorded in the engine log book.
