Continue to disassemble the core Corvair engine. Removed the end casting to expose the timing gears, split the case and did a rough cleaning of sealant and old gaskets from the case halves. The case will be sent out for cleaning and maching as well as the crankshaft. The cam and cam gear will be replaced.
