Finished assembling left airleron. The airlon trailing edges were toed inward and double flush riveted with out the use of glue on the trailing edge wedge. Trailing edge rivets were half set using a rivet squizzer starting with every 1/10 rivet then every 1/5th rivet and then every other rivet. After all rivets were half set a mushroom set and back riveting plat were used to finish the double flush rivet. The end results were very nice.
